A4 Dudes. I gotta tell ya about the ShiftPlus.
Isn't this ShiftPlus thing basically what Trans ams/Formulas have stock?
i also thought the performance mod did the same thing as the B&M? can someone please elaborate if there is any difference between the GM performance mode and the B&M / JET? thanks.
carl
carl
I put a Shift Plus on my brand new trans. After about a year, the trans started to slip very badly, and constantly bounced the rev limiter when shifting. Took it off, changed fluid, and all is well.
Just give it time. Pretty soon those high line pressures will crap out your clutches and bands. Same reason I sold my B&M internal kit. It basically raises the line pressure. Do a search, you will find many people who have had trannys crap out on them because of this.
As far as B&M advertising it won't hurt your tranny ? Dur ! Who the heck is gonna sell something and state "This producst will cause excessive ewear and will almost likely damage your transmission" ?
-Shannon
-Shannon
Originally posted by VegasZ
The attractive thing for me about the ShiftPlus was that you only turn it on when you want to. During normal driving there is no need to have it on. But if your racing or whatever its nice to just be able to raise the line pressure and get that good launch.
shift kit is the way to go
Ive always been told that what kills transmissions is heat. Im a firm beleiver in that. A good tranny cooler and fluid are musts for anybody. Raising line pressure reduces slip. Sure, excessive use I guess can wear out your tranny. So will hard driving.
Im not sure what the performance mode button does on the Firebird, but I do know the Camaros are in performance mode all the time thats why they dont have that option. So the ShiftPlus is something completely different.
Too much line pressure kills trannies. Be very careful with the Shiftplus. It has killed lots of trannies.
The performance mode is not quite the same as the Shiftplus. Many threads on this. Do a search.
Camaros are not in performance mode all the time. That is a myth and not why they do not have the switch (just a difference in the way the two cars are marketed-Pontiacs always get the gizmo stuff
[i]
Im not sure what the performance mode button does on the Firebird, but I do know the Camaros are in performance mode all the time thats why they dont have that option. So the ShiftPlus is something completely different. [/B]
This thread is quickly turning into a whole bunch of Mouth Diarrehea.
Shift Kit Shift Kit Shift Kit...... WHY? So ur forcing MORE Line pressure through ur trans in order to make your trans shift harder. Wow, thats the most ghetto idea I have ever heard and seen in order to increase "performance"
B&M shiftplus boosts line pressure through PCM controls. While this is still not the safest thing to do to a trans, it is a more subtle change. However, I don't see how this is helping u LAUNCH
Too many people are under the misconception that shift kits improve the life of ur trans. Can anyone explain to me how it does that?
Didn't think so.
The only safe and effective way to boost tranny performance through shifting is a complete rebuild. Upgraded clutches, pump rotor, rings, vanes, servo, valves and high pressure springs. That way ur trans will shift and hard and crisp, safely.
Didn't think so.The only safe and effective way to boost tranny performance through shifting is a complete rebuild. Upgraded clutches, pump rotor, rings, vanes, servo, valves and high pressure springs. That way ur trans will shift and hard and crisp, safely.
Originally posted by Cmr0z28
pretty much anything that increases shift firmness via PCM is increasing line pressure, which is BAD!
Good point Shoebox, as always my good man.
Line Pressure is one of those "too much of a good thing" ideas. U need a proper amount of line pressure in order to shift the tranny without slipping. However, going to extremes to increase line pressure raises temperature, as well as reduce the life of springs and clutches, two of the most vital components of an automatic trans.
Wheelman I am having problems understanding what your trying to say.
I have a built 4L60E with a shift kit, I have a stall converter as well and the shifts would be kinda soft without the shift kit.
My tranny shifts nice and crisp and does so without manipulating line pressure through the PCM. Its done through the valve body where I believe it should be done, not the PCM.
As I said, its your car and you can do whatever you want to it, I would never put one of those line pressure boosters on my car.
But a shift kit, hell yes.
A shift kit adds shims and spacers in order to make the Spring compress harder and tighter, thus creating a harder shift right? How is that done through the valve body?
If a trans is built properly, than u CAN adjust line pressure accordingly through the PCM. Just cause u can adjust something through the PCM, doesn't mean it's done improperly.
U can adjust timing in the PCM, but that doesn't mean u would give ur self 60 degrees of raised timing right? So if ur adjusting line pressure, u can do it properly without doing it excessively.
