987 valve spring shims
Old Feb 18, 2005 | 03:08 PM
ftransam1's Avatar
Just wondering do the 987-16 comp cam springs need shims too or just the locators? Getting ready to install everything and want to be sure the springs are in right. I know I have to grind the seats a bit but what else?
Old Feb 18, 2005 | 04:37 PM
Ken95Z28's Avatar
Re: 987 valve spring shims
The shims help setup the spring height, thus setup the spring pressure. You really need to check the spring height if not you can risk running to less of spring pressure and causing valves bounce.
Plus you should already have the retainers, seats and locks.
How are you going to ground the seats? They make cutters for that purpose.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
