987 Spring Question
Old May 19, 2006 | 10:15 AM
  #16
roughneck427's Avatar
Re: 987 Spring Question
Yeah me too i ditched the 987-16 and went with some 977-16 springs havent assembled it yet though
Old May 19, 2006 | 10:39 AM
  #17
Bodenham's Avatar
check out the 26918 springs. they have decent pressures and don't require the open pressure to maintain control because of the lighter weight. I have a set on AFR195's and a .600" cam, street driven LT1 that revs fine to 7000. Ask CC for the correct retainer, the LS1 retainer commonly advertised won't work on 11/32 SBC valves. they have a nice Ti retainer, don't remember the PN.
Old May 19, 2006 | 11:47 AM
  #18
SStrokerAce's Avatar
Originally Posted by calfirebird
I have those on My LE2 heads with an 847 cam should i be looking at getting a diffrent set up springs? Like beehives or something now im worried.
Yeah, the 977's would work with the same parts you have, but the beehives (26918's) will work much better.
Bret
Old May 19, 2006 | 12:59 PM
  #19
hey Stroker so you say the 918 beehives are better than the 977 for what reason being lighter???
Old May 19, 2006 | 01:16 PM
  #20
Yes being lighter, having a lighter retainer and having a lot less change of having a resonance frequency problem.
Bret
Old May 19, 2006 | 03:22 PM
  #21
Bret
Well when is it to much open spring pressure and the HYD lifters start to collapse
Old May 22, 2006 | 01:13 PM
  #22
Depends on your lifters, i've seen much more than you would expect.
Bret
Old May 22, 2006 | 01:53 PM
  #23
Well not to steal this guys thread i have comp 850-16 whats the max on these??
Old May 22, 2006 | 09:59 PM
  #24
850's are stock replacements so 550lbs ish is ok. I've run more but they don't like it as well.
FWIW you get the lbs on the lifter by figuring out you max pressure open then multipling that by the rocker ratio.
Bret
Noenav
Mar 1, 2019 07:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Nov 28, 2014 03:46 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
