98+ Airbox in 95Z
Old Mar 13, 2004 | 10:12 PM
EbeZ28's Avatar
98+ Airbox in 95Z
Is it possible to install a factory LS1 airbox into a earlier (95) Z? I like the looks (and have plans for the space that would open up). I have found some information about adapting the TB to the Airbox. Seems I can kludge some parts from a 92-96 'Vette. Also, it looks to me like the radiator shroud is different, but I don't know about the underside of the 98+ hoods. I actually plan to use one of the 98+ FIPK's if this will work.
Anyone have experience with this swap?
Old Mar 13, 2004 | 10:52 PM
#7's Avatar
I was thinkin about the same thing today.Trying to figure out how to get air rammed into the TB on my 94.Like my FTRA,lid and air box does on the 99. good luck and pass on the info dude
GreenDemon's Avatar
http://www.hpsalvage.com
They might be able to answer that.
I think the radiator support and hood clearance would be your biggest problems, though. If you look on their project cars page they used the LT1 style intake on an LS1 that was fitted into a 95 T/A.
Old Mar 14, 2004 | 08:13 AM
FASTFATBOY's Avatar
That LS1 Trans Am has a LT1 style intake on it. I took a complete LS1 airbox assembly with whisper lid, duct taped it to a LT1 core support and set a 4 inch cowl hood on, ain't gonna fly, even if you cut the whole underside of the hood out and pinned it on. K&N says thier CAI will support 700 FWHP with a bigger cone filter, I called and asked...so there ya go.
David
Old Mar 14, 2004 | 10:25 AM
EbeZ28's Avatar
Follow-up Q's
I re-re-searched and I am PM'ing some folks about the box conversion. I'll post any updates should I come across them.
EDIT: This picture (a 98 conversion my MadKilla) makes me think the shroud/radior brace maybe different. No biggie. Now for the hood. Anyone have shots of the underside of stcok 98+ hood (non-SS preferrably)?
Old Mar 14, 2004 | 10:45 AM
EbeZ28's Avatar
David
I think the radiator shroud (same thing as core support?) needs to be swapped. I just need to sort out if there is some kind of clearance the 98+ hood has that the 93-97 do not.
Thanks!
95mysticta
Aug 20, 2015 07:43 PM
formula218
Dec 2, 2014 04:27 PM
97ss1826
Sep 11, 2002 08:58 AM
RamAir95TA
V6 Tech
Aug 8, 2002 01:34 PM
