97 z28 camaro flat spot
Old Apr 7, 2010 | 09:39 PM
2JZ Supra's Avatar
I'm not good with this kinda stuff , I have just put in a msd distributor, new plugs and wires, also quick trip long tube headers and the y-pipe.
The car runs fine but there is a flat spot in the 0-2000 rpm range then it runs fine, any ideas as 2 what I did or could do 2 fix it?
Old Apr 8, 2010 | 12:54 PM
craby's Avatar
check fuel pressure and scann for trouble codes.
Old Apr 8, 2010 | 12:56 PM
brianswimmer23's Avatar
x2. are you throwing any codes??
Old Apr 8, 2010 | 01:11 PM
Did it exhibit the same "flat spot" BEFORE you made all the changes you listed?
Old Apr 8, 2010 | 06:51 PM
2JZ Supra's Avatar
No it didn't have the flat spot untill i put the stuff on and im getting a code of the downpipe oxygen sensors I was told i didn't need.
NewsBot
Dec 28, 2014 06:20 PM
Dec 4, 2014 11:56 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
NewsBot
Dec 3, 2014 12:30 PM
squarehead
Nov 21, 2014 08:02 PM
