97 z28. Air pump relay necessary?
Old Apr 25, 2011 | 03:09 PM
Henson071's Avatar
I was going through my fuses and noticed the relay is missing. Ive had the car 8 years so I'm sure I took it out when I deleted emissions. But I just read in my manual it controls a bleed valve or something, and cooling fans. I have no air pump and I think my fans work fine. Should I just slap a relay back in or leave it out? Does it matter?
Danny.
Old Apr 25, 2011 | 03:20 PM
Re: 97 z28. Air pump relay necessary?
Shouldn't matter. The AIR pump relay has nothing to do with the fans. They do share a common fuse, though. Maybe that is confusing the situation.
RamAir95TA's Avatar
It's not needed, nor does it control a fan of any type. The "bleed valve" you hear is part of the AIR pump recall components, and it isn't necessary.
Old Apr 25, 2011 | 04:36 PM
NJ-LE's Avatar
I may be wrong (can't look right now) but I think it is the same part# as the fan relays. Save it in the Camaro spare parts box.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Scottyboy
Feb 11, 2015 10:28 PM
CamaroZBoy
Aug 16, 2002 10:03 PM
