97 ws6 engine into a 95z28?????
Old Apr 9, 2005 | 03:30 PM
worak's Avatar
heres the deal. my friend offered to give me 2500 for my engine, plus his stock engine out of his 97 ws6. i dont think it would be a problem to swap the engines. we'd swap engines, computers, exhausts, and rearends. my question is hooking up the induction system on his ws6, all lt1 intakes from 95-97 are the same? we wouldnt have a problem hooking it up to the cammed engine with the programmed computer. my boss who is an old gm service manager says it wont work. i think hes wrong.
Old Apr 9, 2005 | 04:04 PM
Crazy95Z's Avatar
Re: 97 ws6 engine into a 95z28?????
The intakes from 95-97 are the same. Only slight problem I could foresee is 95 is obd1 and 97 is obd2, so you may have to have the computers in both cars reprogrammed for the new engine. That's about it.
Old Apr 9, 2005 | 04:33 PM
worak's Avatar
so even if we swapped computers? will a 97 computer plug into a 95 harness? my computer has been programmed.
Old Apr 9, 2005 | 04:38 PM
madwolf's Avatar
The 97 computer will work in a 95 body, but it will need to be reprogrammed. Also, you will not have a connector for the crank sensor and rear o2s. (which you probably won't even have space for unless you're taking his exhaust as well) So it will work fine if you get it reprogrammed.
97s also have a different coil, so you will need to swap coils/modules with him. Other than that, it should work fine.
Old Apr 9, 2005 | 04:45 PM
worak's Avatar
thanks ion, so whats the price for 2 more programs?
Old Apr 9, 2005 | 04:48 PM
madwolf's Avatar
You only need an update on your OBD1, right? That would be $40+$13 shipping and another $107 for the OBDII. (discounted 15%)
Old Apr 9, 2005 | 04:57 PM
worak's Avatar
that sounds good ill let you know. what about the idea of swapping out the wiring harness too, would a program be easier? can you program out the crank sensor?
Old Apr 9, 2005 | 04:59 PM
madwolf's Avatar
No, you don't want to swap harnesses. Yes, I can program out the crank sensor.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
TitoPR221
Jan 2, 2015 03:51 PM
shanezam203
Feb 8, 2003 08:24 PM
