97 Trans am....cooling fans issues???
Old Mar 23, 2014 | 03:21 PM
bman101's Avatar
My cooling fans come on with the ignition turned on and never goes off until the car is off....no check eng. lights or anything like that is visual... is this something that has been tuned or????? A4 car
Old Mar 23, 2014 | 04:09 PM
Andrew88ZT56's Avatar
Re: 97 Trans am....cooling fans issues???
Any possibility a prior owner installed a fan switch or wired them to be always-on?
Old Mar 23, 2014 | 04:38 PM
Does your check engine light work?
Old Mar 23, 2014 | 04:39 PM
bman101's Avatar
I am not seeing any toggle switches for it and it looks like it has the factory
plugs to the fans.....any other places or things to look for onlong those lines??
Old Mar 23, 2014 | 04:47 PM
bman101's Avatar
I see it as it starts then goes off (check engine light)
Old Mar 23, 2014 | 07:43 PM
I'd put a scanner on it to see if the fans are being commanded on or there are any possible trouble codes.
Old Mar 24, 2014 | 11:18 AM
bman101's Avatar
so you can get error codes that are not seen through the instrument panel???
Old Mar 24, 2014 | 12:16 PM
Yes, there are some, but not sure if they turn the fans on. That is why I suggest the scanner for fan command status. You have to start ruling things out somewhere...
Old Mar 24, 2014 | 01:14 PM
The right scanner can do more than provide codes. It can read the various sensors, and the calculated engine operating parameters, allowing you to look at whether the data coming into the PCM from the sensors is correct, and whether the PCM is producing the required responses to the data.
Old Mar 30, 2014 | 08:03 PM
bman101's Avatar
Update..... no codes thrown....did find one fan running off a fusable link going into the fuse box under the hood...disconnected that and plugged reg. plug back into fan but fans didnt come on after temps reaches around 200 on gage.....any thoughts any one???
Old Mar 30, 2014 | 09:19 PM
That may be "normal" fan operation, the stock programming doesn't turn on the primary fan until somewhere around 225 degrees, if I recall. You could try turning on the A/C, to see if the primary (LH) fan turns on.
Old Mar 30, 2014 | 10:48 PM
No "primary/secondary" late 94 and newer. Both fans on low at 226°F, both fans on high ar 235°F.
Old Mar 31, 2014 | 11:49 AM
Forgot all about that change.
PCLZ28
Dec 24, 2015 05:19 PM
jackpawt883
Feb 26, 2015 09:04 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
