97 SS Computer bad?
97 SS Computer bad?
My 97 SS was running fine, a week after swapping on a new Opti, and now it won't restart. The fuel pump is priming, and the engine will turn over but not start. There is no fire at the plugs or at the coil. I replaced the coil and module with known good ones, and still there is no spark. I even removed the Opti to be sure the drive pin was properly engaged. I connected a scanner and it would not even boot up (its an inexpensive Actron, but I verifed it works on another car). The car was coding before (for the rear O2s) and possibly something else, but was running and starting fine.The Service Engine light and other warning lights come on when the ignition is turned on. It did have a problem I haven't seen before, though; after shutting the car off, it would run on for a couple seconds...not like the "dieseling" you hear on some older carbureted stuff, but more like the ignition was taking a few seconds to respond. Not sure if that is related, but I'm betting it is now that the ignition system isn't functioning at all. Any ideas? Thanks guys!
Re: 97 SS Computer bad?
Yes, its an OBD-II scanner...I tested it on a 2001 Z28. I forgot to mention, I have also checked all the fuses (both locations). I have a spare OBD-I computer that I will put in today to see if it cures the problem before buying another one (its calibrated for my old motor).
Well, I assume the former OPTI was shot and that is why you swapped it out for a new/different one?? I would ask how the first one died and then entertain the thought that maybe the new one is toasted also.
Just a thought.
Just a thought.
Just a thought.
Just a thought.
Just in case. I have two obd II pcms in my living room right now. One's out of my 96 that had 68,000 miles on it and the other is a core I forgot to return to Ion. Feel free to PM me if you want to buy one off me.
Mike
Mike
Henson071
May 4, 2015 12:23 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
Jan 5, 2015 07:14 PM
