97 LT1 Z28 Back Firing
Old Dec 14, 2024 | 11:01 AM
weedog's Avatar
97 z28 back firing
Old Dec 14, 2024 | 11:09 AM
weedog's Avatar
Re: 97 LT1 Z28 Back Firing
Had a speed shop build the motor finally got the motor back in and Frist time I Tried to crank it backfired 2 times. Did not try it no more that day. The next day I tried it again and never tried to crank. All it did was shoot fire out the passenger side about 1 1/2 feet and the driver side a little smoke came out of it. I have not tried it today can someone tell me where to look for problem. Thanks
Old Dec 15, 2024 | 07:35 AM
Check plug wire routing. Next would be opti indexing.
Old Dec 15, 2024 | 08:50 AM
Did the shop test run the engine before delivering it? Incorrect timing chain install, valves too tight, etc., but they should have caught that. Start with Shoebox's recommendations.
Is the engine basically “stockish”, or has the camshaft, heads, injectors, etc. been upgraded? If so has the tune been modified?
Old Dec 15, 2024 | 11:57 AM
weedog's Avatar
Everything on the motor is new. The heads were done by Lloyd Elliott I had the LE2 370 to 410 rwhp and TB 58mm. Got my TB from Arizona Speed Marine. Had it bored 30 over 1.6 roller rockers comp cam long tube pacesetter headers. I have checked the plug wires 4 or five time they are right. The motor was never crank there I got it and had to put intake on it. Ever thing on this car is new even gas tank fuel pump relay and fuel pump. How would i check the opti indexing.Thanks for the feed back.
Old Dec 15, 2024 | 12:02 PM
weedog's Avatar
Sorry I forgot the Injectors are 36LB Trick Flow Computer was done by Moe at MoreHorsePower.
Old Dec 15, 2024 | 04:30 PM
You use the term “crank”. Not everyone uses that term the same way. Appears the starter cranks the engine just fine, and you have spark. If the plug wires are correct, the Opti may not be indexed correctly. Who installed the Opti? If the cam dowel pin was a bit too short, it can end up in the wrong hole. Or the shop wasn’t careful installing the Opti.
http://shbox.com/1/opti_back.jpg
http://shbox.com/1/opti.jpg
Then there's the timing chain install:
4th Gen LT1 F-body Cam Install
http://shbox.com/ci/sprockets.jpg
Valve adjustment:
4th Gen LT1 F-body Tech Articles
And the flames are shooting out of the fully installed exhaust? Takes a lot of excess gasoline.
Are there any signs of “backfiring” into the intake manifold?
And you told Moe the injectors are 36#?
Old Dec 17, 2024 | 06:46 PM
irocbsa's Avatar
The backfire is coming from the exhaust, correct? That’s a bit of good news. Backfiring through the intake manifold rarely results in anything remotely good. I think you’re pulling the opti, as mentioned, to start off with and then testing the injectors to see if one is stuck open. When the opti is off, pull the timing cover and check to see that the sprockets are indexed correctly. If the cam gear is a couple of teeth off it can cause exactly what you’re describing.
Old Dec 20, 2024 | 02:18 PM
Robs97Z28's Avatar
Sounds like a fun build! I would to hear what the fix was... Im about to rebuild the engine in my 97 z.. good luck
Old Dec 25, 2024 | 11:23 AM
weedog's Avatar
Sorry so long to reply been sick. No, the speed shop never crank the engine. I had to put the intake on it myself. I also sent Moe Bailey a spec sheet all that was done to the engine. I have the open Pacesetters headers on it. I was going to put the y-pipe on it that came with the headers but it want work i got them from Jed's back in June 2020 and the other day find out they are closed. Where could I find a y-pipe that will fit the Pacesetters and mount to the bracket on the 6-speed trans. And yes, I told him about the 36lb trick flows. The engine will spin over just find but never tries to crank just backfires every now and then. I have had a friend of mine help run the plug wires 6 or 7 times i think we have them right. Thanks Again Merry Xmas
Old Dec 25, 2024 | 12:32 PM
Who installed the Opti? What brand? New or used?
Not sure what you mean by saying you thought the headers were “open” but you found out they were “closed”???
If it does start, when the PCM goes into closed loop, the O2 sensors in the collectors will not read correctly without a Y-pipe.
Given the limited info, you have to start working your way through the possible causes three of us listed above.
Old Dec 25, 2024 | 12:42 PM
weedog's Avatar
I meant no y-pipe on them sorry. I got the Opti from Petris Enterprises it was New. The Speed Shop put it in. Thanks
Old Feb 23, 2025 | 12:37 PM
This has been resolved:
https://www.camaroz28.com/forums/lt1...gauges-890197/
Opti was installed incorrectly.
daddiesLTwon
Parts Wanted
Sep 1, 2011 07:54 AM
METALBEAST
Wheels and Tires
Nov 26, 2007 12:39 PM
cn97z28
Middle Atlantic
Nov 16, 2005 04:18 PM
96speed
West South Central
Apr 29, 2003 04:52 PM
