gauges
Old Feb 23, 2025 | 12:26 PM
weedog's Avatar
gauges
Finally got my car running it was the opit spark put on wrong now the gauges don't work right could someone help me with that I will be posting pictures of my 3-year build. Thanks to all that help me on here all so Thanks for the help from Mo Bailey & Arizona Speed Marine & Lloyd Elliott & Trans Am Creations. Trans Am Creations in Helfin Al has about anything you need for Camaro & Trans Am & Corvette. Thanks To All
Old Feb 23, 2025 | 12:33 PM
Re: gauges
Year of vehicle? ? ? ?
Old Feb 23, 2025 | 12:53 PM
Re: gauges
Which gauges - fuel, coolant, oil, volts, or tach and speedometer, or all?
If "do not work right" means not working at all, did you check the GAGES fuse (#9 in instrument panel fuse block)? Also the POWER ACCY fuse #7.
If it means they are working but not indicating the correct values, describe in detail what they are doing.
Old Feb 23, 2025 | 01:53 PM
weedog's Avatar
Re: gauges
1997 Z28 somewhere around 450 rwhp
Old Feb 23, 2025 | 01:55 PM
weedog's Avatar
Re: gauges
oil it skips as it goes up then stays up around 50 for some time before it goes down
Old Feb 23, 2025 | 03:17 PM
Re: gauges
If this is a brand new engine build, you need to get a mechanical pressure gauge on there before you run it again. Could be a problem with the oil pump or engine internals. Priority before assuming the gauge, sensor, or wiring is at fault.
https://www.camaroz28.com/forums/lt1...nature-879835/
Old Feb 23, 2025 | 06:31 PM
weedog's Avatar
Re: gauges
Josh maxwell
Dec 18, 2011 10:54 PM
one wicked element
Jan 18, 2010 01:05 PM
A 2 Z-28
V6 Tech
Dec 4, 2003 08:50 AM
c1989rs
Parts Wanted
Nov 30, 2003 01:23 PM
globalco
Advanced Tech
Jun 3, 2003 11:29 PM
