97 LT1 - Won't start, no spark - help
Old Nov 28, 2006 | 10:14 PM
hambone1's Avatar
engine was running fine, quit, won't start, no spark. Replaced fuel pump last month. 69k miles What could it be. help
Old Nov 29, 2006 | 05:23 AM
Guest47904's Avatar
Guest
Assuming you checked for spark at a plug only, then check for spark at the coil. If at the coil and not a couple of plugs, check the coil wire to the opti or the cap or the rotor.
If not at the coil, check for the presence of ground and 12 volts at the coil as well as the IC signal to the ICM on the white wire.
Old Nov 29, 2006 | 07:52 AM
Sweetred95ta's Avatar
Here you go.
http://www.mainstreamtopics.com/foru...p?showtopic=78
Noenav
Mar 1, 2019 07:38 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
nophix
Nov 30, 2014 10:26 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
