97 LT1 into a 89 bird
Old May 4, 2004 | 09:34 PM
durtybird's Avatar
Question 97 LT1 into a 89 bird
can anyone give me info on where i can find info or tell me how hard it would be and how and what i need to put a lt1 into a 3rd gen ive been searching everywhere and no luck yet
thanks
jon
(durtybird)
Old May 5, 2004 | 08:37 AM
Berly_BoneStock's Avatar
Well i have researched this quite extensively myself. I can tell you this much. If you are swapping tranny's you will need a modified cross member. If you use the lt1 style six speed the stock drive shaft is supposed to bolt right up. The Actual engine should bolt up. However you may have to fab some motor mounts. In my opinion the absolute hardest thing would be the wiring. Grab yourself an aftermarket wiring harness like the one from painless performance and you should be golden.
Shoot me a message on aol if you want.
aim sn: Vaderx007
Old May 5, 2004 | 12:11 PM
camarochick350's Avatar
try the web site http://www.thirdgen.org lots of good info about what your looking for.
Old May 5, 2004 | 12:19 PM
Pasky's Avatar
Why grab a new wiring harness, The painless harnesses are far from painless and still require splicing. If your really after a plug and play harness, go www.speartech.com they will custom make yours to length and you'll still end up with more money than you woudl if you go through painless, and it will be 100% plug in. A
fter looking back now, its not hard at all. The hardest part by far is just getting everything you need. Motor mounts do not need to be worked up, you can use any thirdgen V8 motor mounts and as far as the clamshells you need v8 thirdgen clamshells or you can get them off a silverado. The crossmember needs to be pounded back if you want to keep AC. Its all pretty easy work. Knowing what to do is half the battle and after going through this myself, I bet I could do everything within one week given I have all the right parts on hand.
Old May 5, 2004 | 12:48 PM
88irocz28's Avatar
You can get the crossmember already modified and painted from www.skulte.com
Old May 5, 2004 | 12:54 PM
Pasky's Avatar
Cheaper at spohn....$110 compared to $145.
Old May 5, 2004 | 01:30 PM
aintno6's Avatar
Its funny that you mention this. Because GM High Tech Performance is doing a project like this right now.
So grab the latest issue on the stands now. And the backordered issue from the last issue.
Old May 5, 2004 | 01:31 PM
Pasky's Avatar
Knowing them they will leave all the important stuff out as usual, not to mention use expensive items.
Old May 5, 2004 | 09:00 PM
durtybird's Avatar
thanks everyone for the help i appreciate it .pasky what is clamshell and waht kind of tranny did you have before the swap and what did you have after i have auto now and im gonna have autp afterwards too
Sixer-Bird
34
Aug 31, 2002 12:59 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Caps94ZODG
9
Jul 26, 2002 03:36 PM
formula79
9
Jul 4, 2002 02:46 AM
joink
Sep 19, 2001 03:16 PM
