97 lt1 car ?
Old Dec 15, 2003 | 05:06 PM
97 FIREHAWK's Avatar
Question 97 lt1 car ?
i have a 97 lt1 firebird for about 2 months now the car has been runing like crap what it is doing is it feels like it is miss firing so i changed the plugs, wires, fuel filter, and it is still doing it does any body have any ideas thanks
Old Dec 15, 2003 | 05:07 PM
Josh-'04 GTO's Avatar
I don't think it's possible to say the words "LT1" and "running crappy" in the same sentence without mentioning the opti-spark! Definitely a possibility.
Old Dec 15, 2003 | 06:42 PM
simple's Avatar
Re: 97 lt1 car ?
thats kind of a vague description! care to elaborate a little bit more on exactly what and when and how it is doing it?
Old Dec 16, 2003 | 12:43 PM
If its misfiring, you should be getting a flashing SES light. Have you ever had it scanned? They can pull up the misfire count by cylinder, which may point you in the correct direction.
Old Dec 17, 2003 | 10:01 AM
LT4Firehawk's Avatar
1) Get it scanned for any codes
2) Double check to make sure you have the wires going to the proper plugs
3) start thinking about changing the opti
Old Dec 17, 2003 | 11:00 AM
97-1LE's Avatar
When's the last time the fuel filter was changed?
Old Dec 17, 2003 | 12:36 PM
IXLR894Z28's Avatar
Since you just changed the filter which rules that out, I'd say fuel pump or opti.
Old Dec 17, 2003 | 04:19 PM
Waistin_Rubber's Avatar
Its getting into the winter months...It is possible that you have bad fuel in your car. That can cause it to act up. Have no power, miss and other problems.
If you think you could have water in your fuel. I believe "Heat" will take care of it. Just something to look at.
Old Dec 17, 2003 | 05:14 PM
2cub49's Avatar
Check to see if the waterpump is leaking on the opti
GhostZ28
Dec 7, 2014 11:53 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
Jul 4, 2005 05:00 PM
