97 LT1 in a 93
Old Feb 9, 2006 | 05:05 PM
  #16
Jazsun's Avatar
Re: 97 LT1 in a 93
Im going to try and look at it this weekend. I looked up the carfax and it has had 5 owners! Kinda scary but then again my current car is a 93 and has 5 including me.
Old Feb 9, 2006 | 05:28 PM
  #17
Fastbird93's Avatar
Re: 97 LT1 in a 93
An LT1 is an LT1. It's the stuff on the outside (save for early/late cams) that makes the difference. Just the longblock with the opti and everything but manifolds would drop right in save for just a couple of things. THe 93 IAC is a screw in type with a square four pin connector while the 94+ IAC is a bolt in and uses a flat 4 pin connector. The crankshaft position sensor on the 97 motor's timing cover would remain disconnected as there's no provision in the 93 harness for that. If it came with the vented opti, great, just use the vented opti harness and you're good to go. Other than those two things, the motor should just drop right in and the 93 manifolds would bolt right up to the heads.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
