What else is needed for Heads/Cam swap?
Old Feb 9, 2006 | 12:32 PM
TireMarx723's Avatar
OK
I want to have all the parts ready for my upcoming LE2 project.
What other parts do I need to do the swap?
I already have 52mm TB, K&N intake, 4" Mufflex, and 1 3/4 Hooker LT's ready to go. What else do I need, or what else would help my power output?
Electric Water Pump
36lb Injectors
1.6 RR (NSA or not?)
Do i need different pushrods?
Whats the best timing chain option? or should I get a timing gear?
Can or should i buy a two peice timing chain cover?
What Head gaskets should I get (Thinner=Better?)
What temp spark plugs should I go with?
I cant think of anything else, but maybe you can..
Thanks for any help
Old Feb 9, 2006 | 01:31 PM
Javier97Z28's Avatar
Moderator
Re: What else is needed for Heads/Cam swap?
Since you're picking up an electric water pump, go with a cloyes double roller setup.
Pushrods, I'd recommend a set of comp chromoly pushrods.
Comp 1.6 RR NSA w/ guideplates.
I'm not aware of any two piece timing covers for our cars (not a standard 350 cover due to the opti).
Go with the Mr. Gasket .026 gaskets if your block is untouched.
Check with Lloyd, he recommended a certain NGK plug to me.
Old Feb 9, 2006 | 04:20 PM
Jeff95TA's Avatar
Maybe it's obvious, but a tune.
Old Feb 9, 2006 | 04:30 PM
WS Sick's Avatar
I would also buy ARP head bolts (for a SBC and torque them to ARPs specs), ARP sealant for the threads of the head bolts, and the ARP thread cleaner for the headbolt threads in the block.
For the head gasket I would just buy the felpro peice, its slightly thinner than stock and very sturdy.
If you have guide plates on the heads new hardened pushrods are a must. I like the trickflow 1 peice CM pushrods. they are less than 90$.
Definately get the Comp pro mag steel rockers , very nice. Again if yo have guidepltes get Non self aligning, if no guideplates get the self aligning ones.
The 2 peice cover for aN lt1 is non existant. If you have the cash get the Extreme duty timing set, if not get a FULL new stock set (chain and both gears new). If you go with an elec water pump buy a roller chain for a SBC with factory Hyd roller cam.
I would try the stock heat range and go from there , you might need a 1 step colder , but you may be ok.
Tune is a must as well.
Old Feb 9, 2006 | 04:42 PM
im kinda surprised they dont make a 2 piece cover...makes it a lil easier second time around. oh well, thanks keepem coming...
Old Feb 9, 2006 | 05:55 PM
Bersaglieri's Avatar
Originally Posted by Javier97Z28
Pushrods, I'd recommend a set of comp chromoly pushrods. Pretty Sure Lloyd and Bret recommend Comp Hi-tech's
Comp 1.6 RR NSA w/ guideplates. Definately
Check with Lloyd, he recommended a certain NGK plug to me. NGK R5671-A7 if I heard on the phone right this evening
In agreement with Javier.
-Dustin-
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
