97 LT 1 High idle problem
Old Apr 30, 2012 | 02:30 PM
77 Formula's Avatar
I have 1997 Camaro with a LT 1 it idled fine when I got it then it blew a head gasket I tore it down and replaced the head gasket and now it idles between 1500-2000 rpm. I checked all the vacuum lines and replaced the ones that where bad and it stll idles high.I put an under drive pulley,cold air intake,and header's when I put back together too.I took it to a friend and put on a computer and it shows it's missfiring on 3,5,6.What could be causing this problem.
Old Apr 30, 2012 | 05:29 PM
mrmint69's Avatar
Re: 97 LT 1 High idle problem
Deal with the misfire first and maybe it will go away with that. You did a lot of different things at once, so hard to say what you missed. Go back and check your work on anything you had apart or replaced.
Old Apr 30, 2012 | 08:30 PM
my94blackz's Avatar
Intake leak. Did you dig the old plastic out of the heads from the intake gaskets?
Old May 1, 2012 | 06:45 PM
77 Formula's Avatar
Thanks for the info. I was wondering if the miss may have something to do with it.
Magenta_Hearts
Mar 5, 2015 07:01 AM
ChrisFrez
Mar 1, 2015 01:33 PM
edman
Jan 25, 2015 02:41 PM
IRABuss
Sep 7, 2011 09:08 PM
slothgrant
Aug 22, 2002 03:01 PM
