97 engine @trans in a 94?
Old Dec 6, 2007 | 07:23 PM
slowride94z's Avatar
I've done searches no good info. What does it take to put a 97 or 96 engine and trans in 94? What needs to be changed? What do I need to keep?
Old Dec 7, 2007 | 05:44 AM
Guest47904's Avatar
Guest
The engine harness and PCM from the 97 needs to be with the engine. Unless you do the advisable and change it over to OBDI which is what the 94 had. The 94 has no provision for the CPK or the rear O2's or the second bank KS. They need not be connected.
OBDI is advisable since it's easier to mod than OBDII
Old Dec 7, 2007 | 05:50 AM
The Engineer's Avatar
Also, without the new PCM (95-97) I think you'll have a problem controlling the electronic valve-body in the 4L60E.
WD
Old Dec 7, 2007 | 10:49 AM
96capricemgr's Avatar
WD
The 94 is electronic too it is just not PWM.
Swap the motors leave the cps in place but disconnected. Swap the knock sensor.
Either use your crank hub and pull the cps reluctor from between the hub and crank timing gear or use the 97 hub and always be sure to put the reluctor back in place if you later remove it for any reason.
The 97 hub is slightly shorter to make room for the cps reluctor, the 94 hub is the same length as the 97hub+reluctor.
This will also upgrade you to the vented opti which you will have to make sure you get the wiring harness for.
Old Dec 7, 2007 | 01:04 PM
Good list.... add the Opti vacuum harness to the parts required.
Old Dec 7, 2007 | 04:13 PM
Thanks for all the info to the masters
Old Jan 14, 2008 | 06:56 PM
now I have the 97 engine and trans here, which wiring harness should i use ? staying obd1
Old Jan 15, 2008 | 11:39 AM
To stay OBD-I, you have to use the 94 PCM and the 94 wiring harness. You will end up with several items on the 97 engine that have no connectors on the 94 wiring harness, including (as mentioned above) the CKP sensor and the EVAP vacuum switch. You just don't connect those.
The only problem you will have in conneting the 94 harness to the 97 engine will be the Opti harness extension, running from the gray connector on the bracket on the passenger side of the intake manifold, to the Opti. The 95-97 vented Opti requires a different connector than the 93-94 unvented Opti. You can buy a 97 harness extension from GM, or for about 1/3 of GM's price from Casper Electronics. Perhaps your 97 engine includes the correct harness.
Old Jan 15, 2008 | 09:16 PM
ok got that . the 97 harness has the plug for the opti, looks like it will snap together. What about the second band ks Speedy was refering to just where is it? so I dont hook it up . haha .havent had time to dig in the haynes . sorry to be a pain, im gona get this if it kills me thank you so much
is this not a common swap? im still finding info about the trans. thanks "frank" performabuilt
Old Jan 16, 2008 | 07:58 AM
There is no "second bank KS" on an LT1, unless it came out of a Caprice/SS or a Corvette. All F-Body LT1's only have one knock sensor, on the passenger side. The 97 knock sensor (100kOhms) however, is not compatible with the 94 PCM, so you need to swap the 94 knock sensor (4.5kOhms) into the 97 block.
Old Jan 16, 2008 | 08:19 AM
FASTFATBOY's Avatar
WD
Yup been there done that, there are alot more differences in the 94 trans than people think...not just the PWM solenoid either.
3-2 downshift is different, seperator plate is different. Harness in the pan is different.(Or so I was told)
I put a 97 model trans in my 94 car...I had 1st, 3rd and lockup...that was IT.
Frank at CPT fixed mine to work.
David
Old Jan 16, 2008 | 08:34 PM
thanks fastfatboy, that would have been good to know about a month ago , to late now.
thanks for clearing that up Fred.
got the engine in the k member tonight, possible install thursday night. from the bottom is easer than I thought .
thanks again everyone
Old Jan 24, 2008 | 06:28 PM
I drove my car for the first time today. I got the engine and trans from Fparts on ebay. I have to recomend them. well packaged, plastic and cardboard complete coverage,good pallet. when i cranked it up 75# oil pressure wow. 76000 miles .
when i kicked it the trans killed second gear great.
the list of info given was accurate and complete
I receved info about the trans modification from preformabuilt
thanks to all who helped with this
kidd
Old Jan 24, 2008 | 06:38 PM
FASTFATBOY's Avatar
AWESOME, put some pics up.
David
PCLZ28
Dec 24, 2015 05:19 PM
Jan 5, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
