96 SS No Spark
Old Sep 1, 2011 | 01:37 PM
SS 316's Avatar
96 SS No Spark
My SS quit this morning on the way to work. The car just quit running like you turn the key off. Pulled the car to work it has no spark. Has good fuel pressure. Do have a couple emmison codes don't thing this has anything to do with it. I do have a accel coil on the car going to put the orginal one back in tonight to see it changes anything. anyone got any ideas. Thanks in advance.
Old Sep 1, 2011 | 02:39 PM
Psycho's Avatar
Re: 96 SS No Spark
Check the opti signals.
http://shbox.com/1/4th_gen_tech2.html#opti_test
there is a way to test the factory coil there too.
Old Sep 1, 2011 | 04:48 PM
SS 316's Avatar
Re: 96 SS No Spark
Thanks for the info i will try that tonight
Old Sep 1, 2011 | 07:36 PM
chevy_dude97's Avatar
Re: 96 SS No Spark
high voltage good going into opti? if so check rotor
Old Sep 2, 2011 | 01:30 PM
RobsWS6's Avatar
Re: 96 SS No Spark
Check the fuses. Had the same thing happen to me a little over 10 years ago. Just stopped and it was a blown ignition fuse.
Old Sep 2, 2011 | 03:35 PM
Re: 96 SS No Spark
What are the codes?
Old Sep 7, 2011 | 08:13 PM
SS 316's Avatar
Re: 96 SS No Spark
So today was the first time the weather was good enough to work on my car. I checked the coil it had spark but was a orange color spark. So i was going to move on to checking the opti spark but i found my orginal coil the one that was on the car was an ACCEL. I hooked it up and the car started right up. So to test this i plugged the accel coil back up and the car would not start so looks like i got the easy fix. Guess the accel coil was not strong enough anymore.
Old Sep 7, 2011 | 08:16 PM
SS 316's Avatar
Re: 96 SS No Spark
Injuneer, I still have to fix the codes one of them is catalist efincey below threshold bank one so im going to swap oxgen sensor left to right to see if the code moves. I wll get the other emmison codes and post tommorrow.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
