96 Lt1 start problem
Old Aug 19, 2004 | 03:51 AM
944-LT1's Avatar
I have a Porsche 944 with a 1996 lt1 and the problem is, all of a sudden, it takes 3 to 4 cranks everytime to start. Once it starts it runs perfect. I took one plug out and checked for spark during those first 3-4 cranks and im not getting anything. But, after the 3-4 cranks the plug starts to spark.
So, i run the engine for awhile to warm it up, shut it down, try it again and it does the same thing. I replaced the fuel filter and checked for psi and checks out fine. This has been happening for about 3 weeks now.
Any amount of help will be greatly appreciated.
-Michael
Old Aug 20, 2004 | 08:06 PM
944-LT1's Avatar
Re: 96 Lt1 start problem
Now i checked for spark right after coil... cranked the engine during first 3-4 cranks i get nothing after that it starts to spark. SOOO... Not a fuel problem nor an optispark problem. right? Someones gotta help me.. Anything!!
-Michael
Old Aug 20, 2004 | 08:18 PM
orbitalshock2k's Avatar
Were you the guy in SCC magazine? If so nice swap
Old Aug 21, 2004 | 01:49 PM
944-LT1's Avatar
No, that wasnt me. But hey whats SCC magazine?
Old Aug 21, 2004 | 06:53 PM
Lyle A's Avatar
Are you gettting any resolution codes from the PCM? Check all your wiring connections to the Opti and ICM. It's not uncommon for an opti to fail like that. Sometimes it's more sudden sometimes not. Try swapping out the coil if nothing else.
Old Aug 21, 2004 | 08:38 PM
944-LT1's Avatar
I replaced the ICM with a new one. checked if the opti is getting 12 volts and it is. I just noticed once the engine fires up after the first 3-4 cranks that my tachometer gauge no longer works...WEIRD? Not in drive and not in idle. i Have not checked the computer at all yet i was wondering if i can go to like an autoZone and rent a scanner? can i do that? If you have anymore ideas as soon as you post them ill run out there and check it. THANK YOU FOR HELPING!!!!
-Michael
Old Aug 21, 2004 | 09:41 PM
Lyle A's Avatar
Autozone might rent a scanner. It's worth a try.
Old Aug 23, 2004 | 06:09 PM
944-LT1's Avatar
The coil is in the neiborhood of 5,000 ohms. Is this OK? Anybody have some suggestions. I talked to autozone they don't rent the scanner but will scan it for me. Any help at all will be so much appreciated. Come on guys and girls!
-Michael
Old Sep 14, 2004 | 11:19 PM
944-LT1's Avatar
Ok, problem solved... it turned out to be my optical sensor inside the optispark. I went to autozone and got the optispark complete kit including the cap and rotor for 130.00 with a life-time warranty which is kinda cool. replaced the optispark for me took about 2 hours. got back in the car cranked it started right up unbelievable. all good now thanks everyone for trying to help. ESPECIALLY SHOEBOX.
Old Sep 14, 2004 | 11:37 PM
944v8inDFW's Avatar
God there is more than one of us out there!!
Old Sep 15, 2004 | 11:05 PM
944-LT1's Avatar
Yeah man how are you? Ive seen you on 560sec. love to see your car... Im just starting/finishing my widebody conversion from Gt racing. All fiberglass on the 1987 944. then i need to start putting the big reds on. Should be fun. See ya
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
slothgrant
Aug 22, 2002 03:01 PM
