96 LT1 runs like crap - low coolant light, overheating occasionally
Old Aug 1, 2006 | 11:37 AM
  #16
Re: 96 LT1 runs like crap - low coolant light, overheating occasionally
What's the fuel pressure with the new filter?
If your fuel pump can only put out 22psi, there's something serioulsy wrong with the fuel system. Faulty pump, or faulty fuel pressure regulator. If the epump sounds like its slowing down, it probably is near death.
Old Aug 1, 2006 | 11:55 AM
  #17
EuroticCustoms's Avatar
I took the car to my buddy's house yesterday to use his fuel pressure tester, so I'm not sure what kind of pressure it has now. As far as starting, everything seems the same. Takes 2 to 3 cranks to get it running. But the pump definitely sounds sick. The radio was barely on, and I had to turn it off just to hear the pump after the 2nd cycle.
Old Aug 4, 2006 | 07:56 AM
  #18
mitchntx's Avatar
Originally Posted by EuroticCustoms
Pump or something else?
I was searching through some threads and ran across some talk of a "trap door" for removing the fuel pump. Was wondering if anybody knows of a write-up with pics of exactly where to cut the hole, or at least describe it. Thanks ahead of time
Definitely a pump.
Unfortunately, you just can't buy a pump for a 4th gen. It comes as an assembly that includes, pump, float/sender, wiring, multiple lines, cap ... get ready to drop a couple hundred bucks.
I put a trap door in my race car.
http://www.vilipend.com/~frrax/album...4/CMC_9_05.jpg
What you see there is kind of small, too.
The hard lines run forward and turn 90* to the driver's side. They also go far forward, where the curvature of the bulkhead is.
I enlarged the trap door so that it is about 1/2" from the curvature of the bulkhead and just inside of that "rib" on the driver's side.
I have a rivnut tool and inserted blind nuts into the car's sheet metal so that a #10 stainless steel machine screw holds it in place.
The black edging is door edging material you can get at any parts store. It helps keep the aluminum panel from rattling. I've also added 4 more screws to stop it from rattling.
To cut the door, I bought a $9 cut-off tool from Harbor Freight, drew out where I THOUGHT the trap door needed to be, cut a very small door to make sure and kept enlarging it till I the space I needed.
When using that cut-off wheel, be DAMNED careful. The fuel lines and fuel tank are damned close to the floor of the car. Plunging that wheel into the car will cut the fuel lines and tank. Just skim the surface.
Good luck and HTH
Last edited by Injuneer; Aug 4, 2006 at 09:20 AM. Reason: Photo too large. Changed to a "link"
Old Aug 4, 2006 | 09:17 AM
  #19
Racetronix 255LPH Walro pump only is $160. Adding the wiring kit increases it to $250.
http://www.racetronix.com/Racetronix..._Pump_Kit.html
Old Aug 4, 2006 | 09:39 AM
  #20
CamaroFan71's Avatar
Had the same problem with mine. Had it flushed/filled. Replaced the overflow and thermostat and bled the system constantly. A shop took off the radiator cover and there were a bunch of leaves and dirt that had built up in the radiator fins. I didnt have a way to blow it out so they did and cleaned it with water also. Since then it hasnt even come close to halfway and I went from a 160 stat back to a 180. Now it can sit in traffic all day with the Ac on and no problem, and I live in Phx with 110 degree days.
Old Aug 4, 2006 | 09:40 AM
  #21
also.... really depends on how dirty/dusty the conditions are where you live. clean it well like i mentioned and see if that helps you at all. it was getting so hot and boiling the coolant out it caused my low coolant light to come on. hasnt even blinked since i did that to it.
calaban
May 18, 2020 06:43 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
siguy
Nov 27, 2014 10:07 AM
