96 camaro z28 Lt1 cranks no spark no start
[size=16px]Hello I am having an issue with my car It's a 96 camaro with 50k miles no modifications at all bone stock. It had been sitting covered up for about 6 years. When I first tried to start it up I ended up replacing the fuel pump. After that it kept throwing codes for little stuff mostly sensors and tune up things. Everything I have replaced is OEM. Ignition coil and module. Optispark, plugs wires, pcv valve, brakes, thermostat and both sensors. Air filter, vacuum hose, fuel filter, oil and filter. I'm sure I'm leaving something other small stuff out. Mass air flow sensor and pigtails to Ignition control module as well as to the mass air flow sensor and Ignition coil those are new. The car was running good until that Optispark went out so I ended up replacing it with a autozone one that seem to make it run rough. Took that off replaced it with a Delphi that i found by luck. During that time before the Delphi I noticed the car had a slight rough idle as I thought it was the aftermarket Optispark from autozone. I put the other opti on and it ran rough still intact even worse as it should not. I haven't even drove it barely at all since I've done all this stuff. So then it dawned on me that the autozone Optispark wasn't the issue something else is. The car acted like as if it wasn't getting any gas and was throwing codes again like in reverse of everything I did. It threw the mass air flow sensor that was new replaced that again OEM and it threw the ignition coil I replaced that again OEM. Then the last code was the p01351. So then I went had the module tested its fine. The car finally cut off and will crank good but no start no spark. I checked all the wiring and measures grounds, continuity and power of everything that has been shown in the forum shoebox. I have no idea what it is can anyone help or have any clue? Is it the PCM? That's the last thing I can think of beings it was throwing code after code again in reverse. No one here really works or wants to work on the Lt1s and people who have" mechanics" are stumped. With 50k miles I understand that it was sitting for a long time but it can't be anything that crazy. Oh and the optispark harness is good the signal and power as well as the spark plug spark it's getting no spark I tested that out. Please help if you can I'm worn out on this. I've probably missed something so any help is greatly appreciated. [/size]
Re: 96 camaro z28 Lt1 cranks no spark no start
Have you considered the possibility that P1351 is set by a problem with the white wire from the PCM to pin “B” of the ICM?
Here's the wiring diagram:
http://shbox.com/1/1996_ec_03_ign_system.jpg
Here's a way to check. Scroll down to “ICM Harness”:
4th Gen LT1 F-body Tech Articles
And a quick question - when the starter is cranking the engine, does the tach needle move up (roughly) a couple hundred RPM.
The tach needle not moving at all indicates the PCM isn’t receiving the Opti low resolution signal. To double check, measure the AC volts to pin “B” on the ICM while cranking the engine (per linked procedure above).
Also check the Opti harness following the procedure in the link above. That doesn’t check the Opti, but checks if the PCM is supplying the 12 volt power, 5 volt references, and ground that the Opti cam position sensor needs to function. Does the current Opti have a socket for the “short” Opti harness from the gray connector on the bracket on the passenger side of the intake manifold to the Opti? Or is the Opti a newer style with the harness permanently attached to the Opti case? The harness connector at the Opti can corrode and interfere with the contacts.
Here's a simplified version of the wiring schematic. It's from a 95, but the main difference is that the 97 has a single coil connector, and 95 has a "siamesed" double connector.
Note that in this GM schematic, the order of the pins on the ICM connector is shown as "C A D B" when in actuality the order of the pins on the connector is "A B C D". This is where you find the white wire, and the ICM end you need to check - circuit "423 WHT". That's where you check for a range of "1vac-4vac while cranking". This is the only time you set the meter to AC volts. All the other tests are measuring DC volts. The white wire isn't really an AC circuit, but that's how the pulse to fire the ignition, riding on a 5 DC volts reference can be measured, per the factory service manual.
No AC volts on the white wire = no spark at the plugs.
No low resolution pulses from the Opti to the PCM = no spark at the plugs
http://shbox.com/1/95_ign_system_schematic.jpg
You can't get a “good” Opti for $400. The only reliable source at this time appears to be Petris. Hold on to your wallet…… well only $440 for a 95-97/F-Body.
https://petrisenterprises.com/collections/frontpage
Are you sure the plug wires are tight on the plugs? Did you reuse the metal shield that were on a few of them?
At any point have you cleaned or replaced the fuel injectors? Is the fuel fresh? If it was sitting unstarted for 6 years, fuel could be a problem.
yeah I only had to replace 1 injector and I cleaned the tank when I put in the new fuel pump. Also ran some good stuff in it. I didn't see any meta shield when I was replacing the wires. I went back to check to make sure they were on tight. When I did that I actually got 2 wires mixed up and when I started it it threw the p0303 code but I fixed that. It'd just kinda shakey and acting as if it's not getting enough gas. Hesitant when you step on the gas. No other codes I'll go back and check the wires again. Is it possible it could be the fuel pressure regulator?
