95Z air pump remove
Old Jul 10, 2006 | 05:10 PM
  #16
Re: 95Z air pump remove
You will not get a code in OBD-I when you remove the AIR pump, as long as the fuse in the circuit is good.
94 did not have any vacuum lines associated with the AIR system. The later models had vacuum lines added as part of an AIR pump recall. The recall did not apply to 93/94 cars.
Shoebox has the recall parts diagram on his website:
http://shbox.com/1/air_pump_recall.jpg
Old Jul 10, 2006 | 05:23 PM
  #17
transamdude95's Avatar
Thanks for clearing that up, Fred.
Old Sep 30, 2007 | 12:44 AM
  #18
JFR's Avatar
JFR
I'm removing that metal U pipe, will replace with hoses that go over top of engine away from heat and easy to remove. Makes working on plugs and sides of engine easier.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
