95Z air pump remove
Re: 95Z air pump remove
You will not get a code in OBD-I when you remove the AIR pump, as long as the fuse in the circuit is good.
94 did not have any vacuum lines associated with the AIR system. The later models had vacuum lines added as part of an AIR pump recall. The recall did not apply to 93/94 cars.
Shoebox has the recall parts diagram on his website:
http://shbox.com/1/air_pump_recall.jpg
Thanks for clearing that up, Fred.
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
