95 z28 troubles...
Old Mar 25, 2009 | 04:06 PM
tanks14's Avatar
95 z28 troubles...
I have a 95 z28 and here is the problem i am having with it. When i go to start it, it takes a few cranks to get it going. And today i was driving and the car would randomly stall out every now and then. I replaced the plugs (all but one, the number 2 plug) and changed the fuel filter today as well. Air Filter has been changed as well. Im starting to think its the opti-spark but idk.
what do you think?
Old Mar 25, 2009 | 04:42 PM
Don 97 SS's Avatar
With 100k on the clock I would recommend that you clean your TB, and particularly the IAC.
Old Mar 25, 2009 | 05:57 PM
z275plus's Avatar
Sounds like your opti is about to crap out on you.
Old Mar 25, 2009 | 09:07 PM
tanks14's Avatar
excuse me for being kinda slow, but whats a TB?
Old Mar 26, 2009 | 07:41 AM
Don 97 SS's Avatar
Throttle Body
Idle Air Control
Old Mar 27, 2009 | 08:36 AM
tanks14's Avatar
alright, thanks. Got a new low spark side of the optispark, so lets see if that fixes it. (there was oil in the old one so....)
Old Mar 27, 2009 | 08:53 AM
Don 97 SS's Avatar
If you have 100k on the oem opti, it might be wise to do a complete replacement since you have it apart.
Old Mar 27, 2009 | 02:42 PM
tanks14's Avatar
yea well the cover was cleaned and hopefully this fixes it. I hate not having my car.
Old Mar 27, 2009 | 07:02 PM
MTBSully's Avatar
also check to make sure you have good fuel pressure, which is a very common problem when hard starting is involved
Old Mar 27, 2009 | 10:31 PM
football4life's Avatar
+1 for that, Sounds like you fuel pump could be going out on you.
Old Mar 28, 2009 | 07:59 AM
tanks14's Avatar
thanks for all the help guys, but found out what the issue was last night, after putting everything back in. It was the ignition swich that went bad, so right now my car is jumped till i can get the switch today.
Old Mar 28, 2009 | 10:16 PM
tanks14's Avatar
found the issue, it was the security system.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
