95 Z28 Suspension
Old Jun 25, 2003 | 12:32 PM
KevmaroZ28's Avatar
95 Z28 Suspension
First time post, new member.
Hello fellow members. I'm Kevin =)
I recently purchased a 02 Z28 w/8K miles on it and noticed a night to day difference in the ride compared to my 95 Z28 w/150K miles, 3rd set of GM dealer replaced shocks & struts.
Additional: Lots of creeking, squeeking and minor popping is experienced from the 95 Z28
Conditions: Daily driver, Calif Freeways. No strip runs. Minor - Med open road runs 100 - 130 mph lonesome desert straights.
95 Z28: Stock Engine, AM Exhaust, BFG Comp T/A 255/50/ZR16
What would the group recommend I do to achieve that nice tight factory enjoyable ride or better than factory.
I can spend some cash on this subject, within reason tho.
Old Jun 25, 2003 | 01:44 PM
anaik's Avatar
Welcome Kevin,
Replace the rubber bushings in the suspension with new rubber or switch to polyurethane ones. Polyurethane will transmit more vibrations though.
Old Jun 25, 2003 | 01:46 PM
Lab's Avatar
Lab
Subframe connectors make a HUGE improvment. Even help your new car.
Lance
Old Jun 25, 2003 | 02:43 PM
Add HD Bilstein shocks to the list. Might as well get a set of replacement springs from SLP while they stil lhave them (if you want stock springs). Dirt cheap, too.
Old Jun 25, 2003 | 03:05 PM
TheHeadFL's Avatar
Its an older car, and older cars do tend to flex and bend more in my opinion. When I went to put on my SFCs, not everything lined up perfectly. I think it was from years of chassis flex.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Hurin
Dec 13, 2014 07:38 PM
1LEThumper
Jul 14, 2003 12:45 PM
