95 z28 overheating
Old Mar 25, 2011 | 03:16 PM
dirkdiggler11's Avatar
Exclamation 95 z28 overheating
Okay so the car (95 z28) was leaking coolant, and we replaced the waterpmp, thermostat, and I also had to put a new radiator in it. Now theres no leaks, but the car is overheating really quickly. After putting the air intake assembly back on, now the fans won't turn on, but if you unplug the cord going to the mass air flow sensor, the fans work fine. We have put the old thermostat back in to see if that worked, a new temp sensor, and it it is still overheating even with the fans on. I am clueless on what it could be. Any ideas?
Old Mar 25, 2011 | 03:55 PM
moparman's Avatar
Re: 95 z28 overheating
Could be air in the system. Did you bleed it until nothing but coolant came out of the screws?
Old Mar 25, 2011 | 04:10 PM
I know this probably sounds dumb as hell, but I just bought this car 2 weeks ago. I was messing with the screw, but i'm not sure if I am using it properly.
Old Mar 25, 2011 | 04:28 PM
Okayso with the engine running, the bolt needs to be removed and the heat needs to be on, and it needs to run until coolant is flowing out of the hole?
Old Mar 25, 2011 | 05:12 PM
Read the refill portion of this info. Bleed screws only need to be cracked open to allow air to escape and to be able to close them quickly. You can easily lose them if take out.
Old Mar 25, 2011 | 08:04 PM
Well we completely took it out (carefully), bleed the system, and that was definately the issue. No more overheating, and runs great. Got to drive it for the first real time today. These things are monsters.
Old Mar 26, 2011 | 06:53 AM
The bleeder screws are designed to correctly bleed the system without removing them. Listen to Shoebox.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
