95 z28 overheating
Okay so the car (95 z28) was leaking coolant, and we replaced the waterpmp, thermostat, and I also had to put a new radiator in it. Now theres no leaks, but the car is overheating really quickly. After putting the air intake assembly back on, now the fans won't turn on, but if you unplug the cord going to the mass air flow sensor, the fans work fine. We have put the old thermostat back in to see if that worked, a new temp sensor, and it it is still overheating even with the fans on. I am clueless on what it could be. Any ideas?
Re: 95 z28 overheating
Read the refill portion of this info. Bleed screws only need to be cracked open to allow air to escape and to be able to close them quickly. You can easily lose them if take out.
Well we completely took it out (carefully), bleed the system, and that was definately the issue. No more overheating, and runs great. Got to drive it for the first real time today. These things are monsters.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
