95 z28 oil pressure drops
Old Apr 18, 2011 | 12:09 PM
DTRJAR's Avatar
Unhappy 95 z28 oil pressure drops
ok i have a 95 z28 355 when it gets wormed up the oil pressure drops to all most 0 need help asap thanks
Old Apr 18, 2011 | 02:41 PM
Cabikejumper's Avatar
Re: 95 z28 oil pressure drops
Mine does that too...
Old Apr 18, 2011 | 02:56 PM
DTRJAR's Avatar
Do u know know why
Old Apr 18, 2011 | 03:01 PM
I'm unsure of the cause. But when I changed my plugs, and fuel filter it went away.
It started doing it again slightly today. Well have to wait for others to chime In on the exact cause.
Old Apr 18, 2011 | 03:38 PM
bw_hunter's Avatar
Does the check gauges light come on?
Old Apr 18, 2011 | 03:39 PM
DTRJAR's Avatar
No it don't
Old Apr 18, 2011 | 03:54 PM
Could be a problem with the o/p sensor. Installing a mechanical gauge to verify pressure would help determine.
Old Apr 18, 2011 | 04:02 PM
bw_hunter's Avatar
Or there could be nothing wrong at all. The gauge isn't very accuate to begin with....
I asked about the check gauges light as it's supposed to illuminate when the oil pressure is below 6 psi.
I would first remove the plug from the sensor and see what the reading is...it should read gauge maximum. Then ground out the sensor and it should read zero. If this checks out you can assume the wiring is fine. Then attach the manual gauge as Rob suggests. There is a plug in the side of the block just above the oil filter that is a convenient place to attach the gauge.
WHen did you last change the oil and what weight did you use?
Old Apr 18, 2011 | 04:38 PM
When its warmed up, at what RPM does the pressure drop to "0"..... at idle?
What is the pressure at 2,000RPM?
Old Apr 19, 2011 | 01:39 AM
DTRJAR's Avatar
It's the gauge or sender I put manual gauge on and at 800 rpms it's at 25 psi and at like 5000 it's at 60
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
