95 z28 m6 ignition problem
Old Jul 4, 2013 | 03:16 AM
Patrick Kovack's Avatar
I traded for a 95 z car has headers cam and exhaust right now i am experiencing a problem with the plug wires melting .
I have read other posts and have been trying to find over the valve cover wire sets and have had 0 luck . please help ..... also need to know where to get a good tune for the car
Old Jul 4, 2013 | 12:08 PM
slick1hunting's Avatar
Thunder racing used to sell to different kits but I guess they went out of business a couple months ago. Pretty much what you need is a good cut to fit set of wires, terminal ends for lt-ls, and some good wire seperators (this part was what thunder racing had that determined the two kits and the only thing that will need some thinking with. I think one mounted on top of valve covers at each bolt and one mounted and routed on the side of valve covers.
Posted from Camaroz28.com App for Android
Old Jul 4, 2013 | 02:30 PM
RUDEDOG's Avatar
Re: 95 z28 m6 ignition problem
I made my own otvc harness out of some cut to fit MSD Superconductors and some Moroso wire loomes.
Old Jul 6, 2013 | 11:55 PM
Do you have any pictures for a ref. Point?
Old Jul 7, 2013 | 12:37 AM
How-to Route Over The Valve Cover Wires | Tech Aids & Articles
Old Jul 7, 2013 | 07:22 AM
smallblockhero58's Avatar
i use to use header wrap when i had a dirt track car, plug wires would melt, after the wrap they never did that again.
Old Jul 14, 2013 | 01:47 AM
OBE1 95Z28's Avatar
Header wrap has the potential to catch fire if oil is spilled on it. It also destroys headers over time. There are high temp sleeves that can be slipped over the ignition wires.
Old Jul 14, 2013 | 09:42 AM
I've had great results with the Taylor woven fiberglass "Fire Sleeves" that slip over the plug wires. Don't hesitate to use nylon ties to hold the plug wires in a position where they can't contact the headers. Of course you have to keep the nylon ties away from the headers as well
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Ari G
Dec 11, 2014 03:21 PM
Jul 4, 2005 05:00 PM
