95 z28 ENGINE INSTALL
Old Jun 12, 2019 | 03:04 PM
Sidewyz28's Avatar
I’m going to be swapping my 95 z28 motor/trans into another 95 z28 chassis
how do I make sure everything is lined up? Do I have to square the k member or should everything fall into place? Any input is appreciated!
Old Jun 12, 2019 | 03:38 PM
Re: 95 z28 ENGINE INSTALL
Since you ask about "square(ing) the k member", can we assume you are dropping out the compete K-member/engine/trans assembly, and rolling it under the new chassis? If so, the ends of the K-member, where the bolts are that attach it to the subframe rails, have locating/alignment pins that fit into holes in the frame rails. Only goes together one way. After you are all done with the complete assembly install, have a complete front end alignment done to account for any variations in the chassis of the two cars.
Old Jun 12, 2019 | 03:43 PM
This is an aftermarket K-member (Spohn), but it shows the locating pins:
https://www.spohn.net/productimages/...-LT1-704-5.jpg
Old Jun 12, 2019 | 03:52 PM
Sidewyz28's Avatar
Thanks man you’ve helped me out a few times on a couple other posts as well, always appreciate the feedback!
darryle
Apr 4, 2017 09:27 AM
tbaarman
Aug 7, 2009 09:54 PM
dutss707
Feb 25, 2007 04:39 PM
fast350camaro
Feb 2, 2005 10:22 PM
Cerwin Vega Fan
Mar 21, 2004 10:15 PM
