95 z28 auto camaro abs and tsr light and trouble starting
Old Mar 13, 2022 | 12:44 PM
Bradhartless's Avatar
I'm having trouble with my abs and tsr lights coming on and It's having trouble starting as well I'll turn the key and it'll click and turn the key a few more times and it will turn over any ideas of what it could be would be helpful thanks in advance
Old Mar 13, 2022 | 01:19 PM
Re: 95 z28 auto camaro abs and tsr light and trouble starting
Which ABS and ASR (Acceleration Slip Regulation in the Camaro) lights are coming on? When? Do they stay on after bulb check? Or do they come on after the engine is started, or at random while you are driving?
Hard starting can be several things - like bad connections at the battery, corroded terminals or corroded cables. Or at the the other ends of those cables - starter and ground. Other possibilities would be damaged ignition switch, or failing starter. Not an unusual problem with a vehicle this old.
Issues with ABS and ASR will set codes. They can be read with a scanner that can access the EBTCM (electronic brake traction control module).
Old Mar 13, 2022 | 02:36 PM
The abs and tsr lights come on and stay on after started it used to do it seldomly now it's more frequent
Old Mar 13, 2022 | 11:26 PM
mrmint69's Avatar
Have you checked to see if the battery is fully charged and that the connections aren't loose or corroded? How old is the battery? Mine usually make it 5-7 years at best.
Old Mar 14, 2022 | 02:58 AM
chevykid's Avatar
i have SES, AIR BAG & ABS lights come on and off from time to time i checked the codes with scan9495 and all it was the idiot bulbs loosing connections, flagging the error codes that the bulbs are not working, which in turn would light up the bulbs.
so the next time i take instrument panel out going to solder in LEDs. i had just took it out last year because ever bulb quit working, clean it up as all the bulbs tested good, everything worked good for a few months then random bulbs started not working and working again.
Old Mar 14, 2022 | 07:38 AM
Low voltage can cause those lights to come on. That coupled with your starting problem seems to indicate you have a loss of battery voltage. Get your battery and charging system checked out.
DanM458
Apr 26, 2011 11:04 PM
why2dogs
Jan 28, 2011 10:18 PM
PWR-TRIP
Apr 28, 2007 04:44 PM
Jazsun
Sep 24, 2005 06:43 PM
jkimbal
Oct 25, 2002 10:29 AM
