95 z28
Old Jun 29, 2021 | 09:18 PM
Warren Maddox's Avatar
95 z28
I have a 93 z28 with a 95 z28 wiring pcm etc…t56 long tube headers motors stock I’m having trouble getting spark I have power to my coil and power in the wiring going to the plug for my opti spark what would cause my opti not to work I just replaced it due to the same issue and it wasn’t a bad opti…
Old Jun 29, 2021 | 11:27 PM
Re: 95 z28
Try the first part of this test (ICM Harness):
courtesy of Shoebox
The key to verifying the Opti signals is the voltage on the white wire (terminal B)
4th Gen LT1 F-body Tech Articles
Have you scanned it for codes? Is your 93 DLC wired correctly to allow you to pull codes w/ an OBD-1 scanner, or scan software?
When cranking the engine with the starter, does the tach needle move up ~200 RPM? Did you rewire the tach to accept signals from the PCM, instead of from the 93 coil/filter?
What brand Opti did you remove, and what brand did you replace it with? Did you check the end of the short Opti harness connector for corrosion, assuming the new Opti did not have an integral “short” harness?
Allanggg2
Oct 3, 2017 09:00 PM
faqz09
Jan 16, 2012 04:14 PM
01Fast
Aug 19, 2010 05:15 AM
kgkern01
Sep 21, 2007 09:41 PM
ColeTrains'96Z28
Jun 13, 2007 01:18 PM
