No spark from coil! BRAND NEW GM Opti. Did Shoebox test's!
ok well this morning i went to start the car and it just cranks. Just put in a BRAND new GM opti, brand new coil, brand new plugs and wires. Ok i did the ShoeBox testing for voltage to the ICM. it get's 12 volts but when cranking it like it says i don't get ANY A/C voltage. So i pulled the harness that comes from the opti and tested the the end that plugs into the PCM harness. Not the side the goes into the opti itself. Anyway, i get NO power there at all. It can't be the opti as it was running GREAT last night but when i went to start it after sitting overnight it won't start. Grrr. this is FRUSTRATING. i've ruled out the ICM as it's getting power but no power coming from the opti Bad Opti harness maybe? don't know if it's been replaced at all. ~Cole~
P.S. Help is GREATLY appreciated as i'd like to get my car back up and running soon here. Thanks
