95 Trans Am 1/4 mile times
Old Jan 23, 2003 | 11:47 PM
stk350's Avatar
A friend of mine let me race there 95 trans am tonite. Ran a consistant 14.6 at 97MPH. Is this a normal time for this car? It has no mods whatsoever and had some awful tires on it. I feel I could have picked up another .10th with traction. I also laid down a RT of .7 so I feel I did what I could with this beast. O' also, it's an auto.
Old Jan 23, 2003 | 11:51 PM
95TA8280's Avatar
I believe stock is like 14.1-14.3..........
Old Jan 23, 2003 | 11:54 PM
neil350's Avatar
What was the sixty and eighth mile times?
97mph is alright, it shows you were spinning hard with that 14.6 et, the crap tires had a huge part to do with it.
In the eight when I was cuting 2.25 sixtys on bad tires, I was still able run 9.1@78mph.
Old Jan 23, 2003 | 11:59 PM
kgkern01's Avatar
I have the same but M6 and with bad tires and diff I ran 9.3's but with 2.3 and 2.4 60' and was running 79 mph.
Old Jan 24, 2003 | 12:54 AM
TrouserSnake's Avatar
if cats and fuel filter are plugged that will always slow a man down. my buddie bought a 94 T/A like mine the fuel filter was oem it was night and day when he got a new one. maybe new plugs too
bunker's Avatar
stock should be around 99-100mph but looks like its all you
Old Jan 24, 2003 | 02:22 AM
bad95z28's Avatar
looks alright for some bad tires. maybe a bit slow but it could be conditions or the car might need a tuneup.
Old Jan 24, 2003 | 04:29 AM
Patman's Avatar
In good tune, with good racing conditions it should run 13.9 or quicker. I've owned two 95s now and both have run 13.9 or better. I bought a 95TA new, with 2.73/A4 and RSAs and in bone stock trim it ran 13.94 at 98.8. My 95 Formula with 3.23/A4, and just better tires, ran 13.89 at 98.2 in stock trim. And I believe my current car will run 13.79 or better now that I've fixed a few issues (vacuum leak, o2 sensors)
Old Jan 24, 2003 | 04:46 AM
TheHeadFL's Avatar
I think 97 mph is quite reasonable and is right in line with 90% of stock LT1s I've seen here in Central Florida. Sure, someone could say that even my car 'needs a tune up' but my engine has 8,000 miles on it. Everything under my hood is new. Wires, plugs, coil, opti, and *engine*. New fuel filter, cleaned injectors, new cats, everything. There is nothing that needs 'tuning up'. It has as much to do with weather as it has to do with anything else in my opinion. Hot humid Florida weather got me a 97.5mph trap speed stock. Cold weather and a Y pipe got me 99mph.
Old Jan 24, 2003 | 09:56 AM
stk350's Avatar
It had to have been 40 degrees lastnite. The track was so could I figured without some hot *** slicks it would have been damn near impossible to hook, so I wasn't going to sweat it. Sorry guys, I also had a passanger and she left the car full of cd's and stuff. I know that car has to run at least a 14.0. Her bro's 97 GPT was running 2 .10ths quicker than us and I was pissed. O well. I laid down 3 consistnt runs with an over weighted car at 14.6 at 97mph. Also. My 1/8th mile time was 12.309.
Old Jan 24, 2003 | 11:42 AM
chesee48's Avatar
I RAN A 14.3 with a 2.4 60ft bone stock...
so that time seems way off...ummm what was your 60ft time? had to be really high im guessing!
Old Jan 24, 2003 | 12:43 PM
larson_lars64's Avatar
that sounds like a normal time for some areas. Alot of it depends on the temperature, elevation, and humidity that day. The higher elevation will slow the car down some.
Old Jan 24, 2003 | 12:47 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
trans ams are capable of consistant 13.8's right out of the factory... any worse than that- it comes down to the driver my formula... with a flowmaster and k&n insert did 13.82, and i spun a good amount at the line... and going into 2nd
Old Jan 24, 2003 | 03:09 PM
LWillmann's Avatar
My best so far, was 14.592 @ 97.2 STOCK. I had a K&N air filter (stock air box) and all the stereo equipment you see on my cardomain page in the car, as well as a child seat.
Old Jan 24, 2003 | 03:33 PM
13.8 is what i ran stock too
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
siguy
Nov 27, 2014 10:07 AM
