95+ opti-spark
Old May 4, 2004 | 01:30 PM
Eff's Avatar
Eff
95+ opti-spark
My opti spark on my 94Z is all f**ked up and I'm looking to replace it.
Someone told me about converting it to a 95 opti. I'm looking at a parts list for
this conversion and I got two questions. Isn't the harness the same from 94 to 95?
And If I did this would I need a different timing chain?
Old May 4, 2004 | 02:03 PM
The end of the harness that plugs into the vented Opti is different from the non-vented version, so you need to replace the harness from the gray connector on the passenger side of the intake manifold to the Opti. The 94 harness plug will not fit into a 95+ Opti socket.
The cam sprocket needs to be changed. Generally when you replace the sprocket you replace the chain, but I guess you could try and get away without changing the chain.
Old May 4, 2004 | 02:48 PM
Eff's Avatar
Eff
thanks
Old May 4, 2004 | 04:50 PM
anaik's Avatar
Don't know if you've seen this, but here's an article on the conversion.
http://para.noid.org/~muttvette/opti.html
Old May 5, 2004 | 07:42 AM
ROLYZ28's Avatar
try looking at the website of delteq
http://www.delteq.com
they have a gr8 conversion which will eliminate any further optispark gremlins
cost +-$ 700
i think it is a worthwile investment
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
VINCELEE123
Sep 29, 2003 05:36 PM
1995redZ28
Mar 19, 2003 11:13 AM
JordonMusser
West South Central
Dec 2, 2002 02:51 PM
