95 LT1 starts, shuts off
I have a 95 LT1 that will start then shut off 3 or 4 times then starts and runs like nothing ever happened. Fuel pressure is 43lb on start then holds on 40lb at idle. I put new pump in bout 7mo ago. What do i need to look at next?
Re: 95 LT1 starts, shuts off
I am having the same exact problem. Fuel pump has been replaced in the last nine months.
You mentioned that you replaced the ignition module? just to confirm is this the part you replaced?
http://shop.advanceautoparts.com/web...1650031998____
fpete1992
Dec 11, 2014 03:51 PM
