95 LT1 starts, shuts off
Old Mar 16, 2011 | 04:02 PM
Danny McAdams's Avatar
I have a 95 LT1 that will start then shut off 3 or 4 times then starts and runs like nothing ever happened. Fuel pressure is 43lb on start then holds on 40lb at idle. I put new pump in bout 7mo ago. What do i need to look at next?
Old Mar 16, 2011 | 06:56 PM
Kevin Blown 95 TA's Avatar
Re: 95 LT1 starts, shuts off
bad ignition switch?
Old Mar 17, 2011 | 05:30 PM
Changed ign switch today seems to solved cutting off prob. Thanks to Kevin.
Old Jul 8, 2011 | 08:16 AM
fernjrivero's Avatar
I am having the same exact problem. Fuel pump has been replaced in the last nine months.
You mentioned that you replaced the ignition module? just to confirm is this the part you replaced?
http://shop.advanceautoparts.com/web...1650031998____
Old Jul 8, 2011 | 08:35 AM
ICM was not mentioned. The switch was.
Old Jul 8, 2011 | 08:42 AM
Thanks for your help shoebox. I will procure the part today and start install tonight, hopefully finishing by tomorrow morning.
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
fpete1992
Dec 11, 2014 03:51 PM
tds1213
Nov 27, 2014 12:55 PM
