'95 LT1 P code engine not getting fuel
Old Nov 27, 2021 | 01:40 PM
  #16
happy2bemad's Avatar
Re: '95 LT1 P code engine not getting fuel
FIXED....
Since all signs pointed to the injectors, I went around to each injector and tapped on the body with a wrench, then tried starting it and it fired right up. I'll put a little injector cleaner in the gas next and let it run a while..
That's unbelievable that all injectors were stuck closed. How does that even happen?
Old Nov 27, 2021 | 04:05 PM
  #17
Stale ethanol blended gasoline can wreak havoc on injectors. They may need to be professionally cleaned.
Old Nov 28, 2021 | 04:21 AM
  #18
mrmint69's Avatar
I buy non ethanol gas, but I didn't know ethanol can cause issues with fuel injected cars. I've heard it's bad on carburetors. I always wondered if it was worth the extra money. Thanks
Old Nov 28, 2021 | 09:57 AM
  #19
The problem occurs because the ethanol absorbs water. When it absorbs enough water, it goes bad, and separates into a layer of water at the bottom of the tank. On top of that is a corrosive layer of ethanol/water mix, and finally a layer of reduced octane gasoline.
This is an article that appears to accurately describe the problems.
https://injectorrepair.com/ethanol-problem/
Old Nov 29, 2021 | 07:16 AM
  #20
mrmint69's Avatar
Great article. I always knew you got better MPG. I assumed I would get better track times using non ethanol. Does anyone know if this is true?
mhcanupp
Dec 20, 2021 10:33 AM
eddiyellowz28
Jun 19, 2020 11:04 AM
jloshotz
Jan 30, 2006 09:03 PM
