95 lt1, bad fuel pump?
Old May 28, 2008 | 06:27 PM
White04GTP's Avatar
we replaced the opti, coil, wires, plugs and new cai. Car ran fine the day before so i parked it and left it for the night. Next morning, i fire it up, get 1 mile down the road and it sputters with me when i give it gas, idles fine for approximately 30 seconds and then dies to about 200 rpms and dies. upon trying to recrank it it turns over and does nothing. wait a few seconds with key in on position it fires. From what i have been reading it seems that the fuel pump is going bad. I replaced the fuel filter and it was rediculously dirty. fuel pump comes on but is LOUD. havent checked fuel pressure do to no time. ANy ideas?
95 M6 lt1 z. msd opti, msd coil, 8.5 wires, tr55 plugs @ 45. bbk underdrive. k&n cai. msd 6al box.
All parts new cept the box. have replaced the fuel filter so far.
If it is the pump, what one do yall reccomend to get.
THANKS JAmes
Old May 28, 2008 | 06:41 PM
You have to check the pressure to rule out or prove pump problems. There is no way around it.
Old May 28, 2008 | 06:42 PM
White04GTP's Avatar
at idle with key on? how much should it read? and thank you for the reply
Old May 28, 2008 | 06:55 PM
30696bird's Avatar
With the car running and vacuum line off it should read 41PSI-47PSI.
Old May 28, 2008 | 06:58 PM
White04GTP's Avatar
ok thanks. any good suggestions on a pump if it is the problem?
Old May 28, 2008 | 07:08 PM
30696bird's Avatar
Walbro 255lph. It's only around $100 and can't handle quite a bit of horsepower.
Old May 28, 2008 | 09:42 PM
Billy Biker's Avatar
THANKS JAmes
Those are the same symptoms my 95 formula gave when the pump died. If you have over 80k on the original pump then its time. There's a step by step somewhere that talks you through cutting a hole in the back of the car under your carpet, and over the fuel pump (and making a nice little door), to replace it without having to drop the back end of the car to get the tank out. Will save you a S!@#$%^D of work especially if you plan on keeping the car for long. These things go through pumps like hookers through mouthwash.
Old May 29, 2008 | 10:54 PM
White04GTP's Avatar
well got the time to hook it up to the pressure tester today. At idle it stays at 14-15 psi. blip the throttle and it drops like HELLLLL NO let off the gas. SO i guess im ordering the racetronix kit for it.
THank you for the advice.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
