95 Lt1 *PROBLEM* Stalling, Starting
Old Mar 24, 2007 | 08:51 PM
hysteria1's Avatar
Exclamation 95 Lt1 *PROBLEM* Stalling, Starting
I have a 95 firebird formula with the lt1 and 6spd. I recently acquired the vehicle and I am having some problems with it. I'm not the most mechanically inclined person which may be making this more difficult than it is. The previous owner was having problems with the distributor and replaced it just before I bought it. I had problems with the vehicle stalling yesterday. This happened while I was in neutral rolling up to a stop. The vehicle started after 3-4 tries and I drove it home. I took the car back out last night to check how it was running and the car died before I could get out of my driveway. This time it would not restart. I hauled the car back up to my house and before parking it I tried starting it back up again and it did this time on the first try. I then parked the car for the night. I went out today to try and start it and it would not. The ignition and all is able to turn over when turning the key but it doesn't seem to be able to get any spark. What could be causing this problem? Could the Distributor be bad again? The car would turn over but not catch any spark. Any info or ideas would be helpful. Thanks
PS. It has been raining the last couple days so this may or may not be a factor.
Old Mar 24, 2007 | 11:05 PM
STAYBG87Z's Avatar
try this,spray the plug wires with water using a misting spray bottle and then have someone crank it and see if the wires are arking.also check fuel pressure,could be a clogged fuel filter.listen to see if the fuel pump is running when it dont start.if you dont hear it running then try pounding on the tank while somebody cranks it
Old Mar 26, 2007 | 08:44 PM
hysteria1's Avatar
anymore ideas?
Old Mar 27, 2007 | 08:51 AM
2000GTP's Avatar
When you put the key in the run position, do you hear the fuel pump prime?
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
1LEThumper
Jul 14, 2003 12:45 PM
