95 impala ss ecu/pcu
Yes it will work, just need to address the knock sensor difference somehow, resistor in the pcm or turning off the code. You can keep the knock sensor and turn off the code and it is supposed to still function. The code is set by different resistance.
What wiring are you going to use??
You can run a 96/97 engine with an OBD-I PCM. Many people convert their 96/97's to OBD-I for simplification, ease of tuning, lower cost tuning and scanning software, etc. You don't need the stuff OBD-II adds - crank position sensor, after cat O2 sensors, EVAP vacuum detection switch, etc.
I would not bother adding the second KS, the f-bodies got by just fine with one and the b-body PCMs are the same PN so I don't see why having only one would be any problem at all.
I was talking about the YEAR difference as 96-7 used a different knock sensor PN than 95 and earlier.
If the pcm doesn't get the signal it's looking for it will retard timing. I tried using the camero knock sensor which was the same as the b body and that didn't cure the problem but attaching the second knock sensor did cure the problem. I had this problem when I had fuel injection specialitys make up a harness to fit a A body and the harness was for a F body, 1 knock sensor while the pcm was from a b body that they programed.
Just trying to keep someone from chasing their tail like I did for 2 weeks.
*86BMFNK 142979RPS* F body 95 transam
*86BMFAK 15094C86Z* B body 95 caprice
