95 heads prone to cracking?
Old Mar 18, 2005 | 08:19 PM
enzo1267's Avatar
Question 95 heads prone to cracking?
is it true that 95 lt1 heads are prone to cracking? i sent my car in for a head gasket and the mechanic told me the head is more than likely cracked! i have never overheated the car...came close but that was a year ago. i baby my car i dont beat on it...s h i t ....i dont think i took it over 95 on the highway!
Old Mar 18, 2005 | 08:25 PM
OBE1 95Z28's Avatar
Re: 95 heads prone to cracking?
NO! Myself and a friend have combined over 220,000 miles on '95 heads in blower applications with no signs of head damage. I believe the 93 - 95 castings were slightly thicker than the 96-97 castings.
Old Mar 18, 2005 | 08:26 PM
brandboZ28's Avatar
The 95 heads are no more proned to cracking that any other year aluminum LT1 heads. Other than some in 96 & 97, they were all the same casting if Im not mistaken.
Old Mar 19, 2005 | 06:16 PM
enzo1267's Avatar
thanks guys
Old Mar 19, 2005 | 07:18 PM
Larnach's Avatar
I ran my car for 25 minutes with no coolant!! My heads warped, but they did not crack.
Old Mar 19, 2005 | 10:19 PM
94zgreenmachine's Avatar
96-97 castings are slighlty thinner. I talked with Lloyd about it and he said you just can't port as much on those heads as you can 92-95 castings.TPIS won't even accept them for an exchange if you were to do the ported heads thru them.
Old Mar 20, 2005 | 10:26 AM
TCAL95Z's Avatar
I'm not sure about that but I have heard a lot of 95's blow head gaskets.
Mine did. They also found a head cracked when they did mine but it wasn't the head that blew the gasket.
Old Mar 22, 2005 | 07:19 PM
93redbird's Avatar
Will 95 heads fit on a 97 LT1. Also will you have to buy anything header wise different when swapping to 95 heads on a 97 LT1.
Thanks for the info.
Tim
Old Mar 22, 2005 | 07:50 PM
Kataklysm's Avatar
They will bolt right up and nothing should be different as far as headers.
Old Mar 24, 2005 | 11:28 PM
arnie's Avatar
I agree. However, that is implying that the deck thickness of the head, is thinner as well. Afterall, that is the area of the head, that is pertinent to this thread, not the wall thickness of the ports.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jlo
Feb 3, 2015 09:41 PM
Chris Anderson
Jan 27, 2015 08:30 AM
squarehead
Nov 21, 2014 08:02 PM
