95 engine into 97, concerns
Old Aug 12, 2013 | 12:39 AM
camzaro28's Avatar
I installed a 95 lt1 into my 97 car. It ran for 2 months, now it has possible bad opti. So its sitting in garage till new opti gets here. But to the point........
I did not swap the timing covers and left the crank position sensor unplugged.
Nor did I put the knock sensor in. From what I read, it should not have even started since the swap. Or am I wrong?
Old Aug 12, 2013 | 08:34 AM
Re: 95 engine into 97, concerns
The crank sensor is only for misfire detection. It has no bearing on how it runs. Though you should have a constant trouble code for the crank sensor not being there. If you did not use your 97's knock sensor, you would also have a code for it. Performance will be considerably impacted because timing advance will be limited with that code.
Old Aug 20, 2013 | 07:33 PM
camzaro28's Avatar
Better late then never!
Thanks shoebox. Car is running again ( put new opti in, and then discovered I had a frayed wire ). It is running good, put about 100 miles on it so far.
Another question for the experts ( Shoebox and Injuneer, you two really are a savior to this site!! ) I bought what I believe to be a 95 longblock. Is there anyway this 95 could have a knock sensor on it? Cause I damn sure have one plugged in, that I didnt switch over. Or possibly previous owner had done this prior......
Thanks again!
Old Aug 20, 2013 | 09:54 PM
Only you can tell us if the knock sensor was there or not. You will have a trouble code if it is the wrong one for the computer. The engine will still run, but timing advance will be limited.
http://shbox.com/1/ks_2.jpg
Old Aug 21, 2013 | 09:32 AM
If you are asking if 95 engines have a knock sensor, the answer is yes.
As Rob has pointed out, the 93-95 knock sensor is not compatible with the 96/97 PCM's. You need to use the knock sensor from your 97.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
