95 Camaro Z28 Ignition fuse keeps blowing!
Old Jul 21, 2006 | 03:11 AM
ussj4brolli's Avatar
Question 95 Camaro Z28 Ignition fuse keeps blowing!
Hi. I was wondering if someone might have an idea why this is happening to my car. It first happend when i flored it, my car just shut off right b4 shifting. I tried starting it, didnt go, so i checked all of the fuses in my car and under the hood. It was my ignition fuse! Its 10 amp, bought a fiew new fuses, put it in, as soon as i put the key to the on position the fuse poped. I had no money to tow my car, so i tried ahigher one, and a higher, finally held at 25A. Held for a fiewdays, then it blew while puting car in reverse. Put another in, drove it up the summet and while going down hill i put it in N and started to coast, and car shut off again and fuse was toasted. Put a 30A in to get home. When i punch it, or even go faster/slowly, the tac and the spedomoter will spike, and bounce all over the place, like my cars going 160 at redlion then 1000 rpm@120 but isnt. I want to take my car to the shop, but was hoping i can maybe get out of that, or atleast save me alot of money for him to diagnose it, maybe someone can point me into the right direction/part. I dont have a car lift, and barly fit under the car, lol. Thanks alot guys.
Old Jul 21, 2006 | 06:45 AM
Re: 95 Camaro Z28 ignition fuse keeps blowing!
Just to verify....by "ignition fuse", do you mean fuse #11 in the underhood box?
Generally a bad idea to put a fuse three times the circuit rating in there... good way to burn the wiring up.
Old Jul 21, 2006 | 06:52 AM
Re: 95 Camaro Z28 Ignition fuse keeps blowing!
Please post only on one forum. I'll merge this thread with the one on "General F-Body Tech & Info".
Old Jul 21, 2006 | 07:46 AM
Sweetred95ta's Avatar
There are a million "blown ignition fuse" threads. Do some searching and you'll find all of the possible answers. Mine popped a fuse when I melted some wires to my header on the passanger side. Maybe that's your problem, but I wouldn't know because I don't know your mods or even what kind of car you have for that matter. Since you're new, learn to use the search function. It can be your best friend.
Old Jul 21, 2006 | 08:30 AM
01Z's Avatar
01Z
Hi. I was just following a thread with the same topic. It turned out to be the automatic transmission range solenoid.
If you are new to the forum (1st post), welcome here. If you can, create a signature that tells a little about your car then the answers can be more specific.
fpete1992
Dec 11, 2014 03:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
2000silverz28
Jul 20, 2002 06:14 AM
