95 Camaro Lt1 Oil Filter Problem ? ? ?
Old Feb 27, 2006 | 01:44 PM
Ihateimports06's Avatar
Angry 95 Camaro Lt1 Oil Filter Problem ? ? ?
I Have A 95 Camaro Lt1 6 Speed I Just Bought Last Week. I Decided To Do A Tune-up On The Car Since There Was Signs Of Neglect To The Motor. Anyways When Changing The Oil, Not To Mention It Was Black And Syrupy As It Could Ever Be. The Oil Filter Was Bent, I Could Not Get The Oil Strap Wrench To Work, So As A Last Resort I Stuck A Screwdriver Through The Filter Hoping To Simply Twist It Off. No Such Luck, I Ripped The Whole Canister Off! So Then I Tried To Stick A Screwdriver In One Of The Drain Holes, And That Dident Work. Heat, Dident Do The Trick, I'm At A Loss, Any Suggestions Would Be Highly Appreicated!
Old Feb 27, 2006 | 02:24 PM
jsetzer's Avatar
Re: 95 Camaro Lt1 Oil Filter Problem ? ? ?
People put the damn things on way too tight.
If you have it tore up that bad can you just tear the rest of it off?
I am trying to imagine what is left stuck to the motor. Can you get a picture?
Old Feb 27, 2006 | 02:48 PM
transamtom's Avatar
Can you get some channel lock pliers on it or vise grips?
Old Feb 27, 2006 | 02:57 PM
SS MPSTR's Avatar
You're going to need to get the female filter threads off.
Old Feb 27, 2006 | 03:04 PM
Roach02's Avatar
just reuse the filter that's on it jk man, i would say go with the channel locks and with a little muscle you should be able to break it free.
Old Feb 27, 2006 | 03:25 PM
Helpful hint for ihateimports06.... turn the "caps lock" key off. That is why the system is capitalizing the first letter of each word. Hard to read....
Old Feb 27, 2006 | 03:35 PM
JohnD's Avatar
Get a big hammer and a long cold chisel and loosen up the bse of the oil filter with that. Be sure you are going in the right direction.
Old Feb 27, 2006 | 03:52 PM
2000GTP's Avatar
A big pair of channel locks usually does the trick for me with stubborn filters.
Old Feb 27, 2006 | 04:08 PM
jsetzer's Avatar
I second the hammer thing.
Yours is a 95 so you probably have the factory oil cooler on there. I was going to say just to remove it but the nut holding it on is underneath the filter....
Old Feb 27, 2006 | 05:02 PM
RamAir95TA's Avatar
Most cars do NOT come with the KC4 oil cooler...
Old Feb 27, 2006 | 05:42 PM
Dave89IROC's Avatar
every one i've messed with does
hammer and chisel trick should wirk for you
Old Feb 27, 2006 | 07:01 PM
FastZinTennessee's Avatar
I've got a '95- no oil cooler. I went to an external cooler on my transmission, so I was thinking about putting a sandwich adapter on the block, and using the trans cooler lines in the radiator (if I get really bored).
Old Feb 27, 2006 | 07:59 PM
Evil Eric's Avatar
Ditto. Pulled a donor motor from a numbers matching 95 1LE and it diddnt have a cooler either
Old Feb 27, 2006 | 10:13 PM
Josh'95Z28conv's Avatar
My 95 has an oil cooler
Use channel locks to get the damn thing off of there. It cant be that hard.
Old Feb 27, 2006 | 10:35 PM
Z95m6's Avatar
My 95 also had an oil cooler it is now on the shelf with all the other junk that use to be on the car.
Dec 1, 2014 08:08 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
Christopher
Sep 14, 2002 03:08 AM
