Is the 95/96 ICM interchangeable for testing purposes?
Old Aug 29, 2006 | 02:11 AM
Blue96z28's Avatar
I have a 95 formula parts car, its ICM is labeled: 466 / 409 4g26
Mine is labeled 466 / 599 5g10
I'm having a miss I'm trying to pin down, I was wondering if its ok to plug up the ICM from it temporarily to see if mine is bad. Although everyone says you can have the ICM tested, I've been to autozone, o'reilys, napa, and pepboys, with no luck, they all say they dont have the connector/some other BS
Old Aug 29, 2006 | 07:00 AM
Re: Is the 95/96 ICM interchangeable for testing purposes?
Whether it would work or not, I don't know. They are two different part numbers.
Old Aug 29, 2006 | 02:09 PM
Blue96z28's Avatar
yea, well the pigtail seems to be the same, I guess I need to do some research and see if the wiring is also the same, if so, would you recommend trying it? or is it 'likely' to damage something, obviously not looking for a 100% answer, just a suggestion from experience.
Old Aug 29, 2006 | 02:31 PM
96TurboTA's Avatar
Call a dealer. They may know. It's worth a shot anyway.
Old Aug 29, 2006 | 05:19 PM
Blue96z28's Avatar
I just took a chance and stuck it on there, car acts exactly the same, so looks like its not the problem, sigh
KYWes
Jun 14, 2022 06:52 AM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
