94Z no start, fuel press solid
Re: 94Z no start, fuel press solid
Update - charged battery to 92% and cranked continuously for 11 sec. could not bear to continue to 20s. Then plugged in with Scan9495. No codes in DTC. engine parameters reading and connected on COM 3. Tried again for about 6 sec while connected. No codes.
i should not have disconnected battery. i wanted to tug the coil wires and such but should have waited. Are there other ways to check why no spark? thanks
Prominent Member
See if Scan9495 shows any RPM while cranking. Anything over 50 would be an indication that the Opti is working. If not, check the cable to the Opti for bad connections.
ok inlaws were here for 2 weeks but i scanned while cranking and rpms do not move, stuck at 45. com working showing vin and current time
plugs to coil and opti secure. will order ac delco opti and update thanks
supercharged94Z28
Jun 2, 2015 03:32 PM
