94 z28 coolant sensor leaking??help
Old Jun 28, 2015 | 08:47 PM
  #16
GaryDoug's Avatar
Prominent Member
Re: 94 z28 coolant sensor leaking??help
Best thing to do is replace the radiator, but I would try to repair the crack (I can be cheap as heck;-). Sand the plastic at the crack inside and outside. Use some two-part epoxy on the inside and outside of the neck and put a screw-type hose clamp around it to allow it to set tight. Leave the hose clamp there forever. Never done this myself, but might work.
Old Jun 28, 2015 | 09:11 PM
  #17
colts0455's Avatar
theres a hair line crack on the neck the sensor pushes into ?? im guessing just old and someone had to big seals at onetime and put lil crack in it ? ive only had cars 3 days i went spent 50 bucks got new sensor with right seals it popped right into it fine took some jp sealing put it on top the crack letting it sit overnight i pray its stopped
Old Jun 28, 2015 | 10:14 PM
  #18
If the tank is cracked, a repair is going to be iffy. The system relief pressure is 18 psi, which is pretty high. If it is the original radiator, it is near time for replacement anyway. The plastic tanks don't last forever.
Old Jun 29, 2015 | 11:00 AM
  #19
colts0455's Avatar
flushing the radiator out now then going for a test drive wish me luck
Old Jun 29, 2015 | 08:29 PM
  #20
colts0455's Avatar
update got new radiator test drove it lil more info in am
calaban
May 18, 2020 06:43 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
