94 vs 95 LT1
Old Jul 3, 2003 | 08:31 AM
lookingformore's Avatar
94 vs 95 LT1
Found an 94 Trans Am wreck...guys wants 2000 for the car.....actually the car is repairable too..but i just want to engine and trans...and would sell off the other parts...i have a 95 camaro...can i use the re-build 94 block and put in in my car ...what would i have to change......need to know major difference if any......and also if any one is looking for 94 parts..here is the car.....damn to drive door..hood..windshield..and front end clip ..everything else is intact.....
Old Jul 3, 2003 | 09:10 AM
94 NO TOP Z's Avatar
About the only difference I know of is the 95 went to a vented opti spark... so the optispark, timing chain cover, cam shaft, cam timing gear are different along with the opti harness. You could use the 94 stuff as is it just wouldn't be the vented opti set-up which is a little better.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
